LCAs too rough for street?
Old Apr 4, 2002 | 03:08 PM
brian89transam's Avatar
I've read quite a few times that stronger LCAs with polyeurethane or polygraphite bushings will increase vibrations and squeeks. Is it worth it without a big hp motor? What about the relocation brackets?
Old Apr 4, 2002 | 03:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have the Lakewoods with poly. No complaints here. I also have the Spohn LCA reloc brackets - IMHO they are the single biggest bang-for-the-buck rear suspension mod. They made a HUGE difference. Again, no ride complaints.
Old Apr 4, 2002 | 03:36 PM
do you have lowering springs?
Old Apr 4, 2002 | 03:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
not particularly
Old Apr 4, 2002 | 09:02 PM
Momar's Avatar
Originally posted by RB83L69
not particularly
hmm.... what do you mean by that? I hope you didnt cut them.
Old Apr 5, 2002 | 12:01 AM
Kandied91z's Avatar
i have the kenny brown lower control arms which are the best out there; they are as affordable as any other set an come designed perfectly; i don't have any of the described problems as well as i don't need relocation brackets either.
i also have the rest of my suspension upgraded an moded, it was the best overall thing i've done to the car to improve driveability. my engine is completely stock, but i'm still in the 12's partly because of the suspension. :hail:
Old Apr 5, 2002 | 07:16 AM
Momar's Avatar
What kind of car do you have and what else have you done to get into the 12s with a stock motor?
Old Apr 5, 2002 | 07:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have the Moog replacement springs with the highest rate and lowest installed height. So this car is lower than it was, but it's still at the stock height for some other cars.
I don't cut springs.
There's no way that control arms alone will rectify the faulty design of the rear suspension of these cars. The problem is that the rear end of the LCA is higher than the front end; so when there's lots of force trying to move the car forward, the rear end is forced to attempt to rotate upwards. This is what causes the wheel hop that these cars all have. Even if you think you don't have wheel hop, you won't believe how much difference it makes to get rid of it.
When I had a 400 with big heads, big roller cam, 800 CFM carb, etc. in this car, I thought I had it hooking up pretty good too... until I put those brackets in there. I discovered what I had been missing.
Old Apr 5, 2002 | 07:47 AM
Momar's Avatar
What does it take to install them by the way, and do you loose ground clearance?
Old Apr 5, 2002 | 09:32 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok wut did u do to get into the 12's ona stock engine? i am having a hard timne beliveing this unless u have a z06 lol
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
drumstixer
Sep 29, 2015 03:02 PM
Jlanz55
Sep 29, 2015 08:55 AM
