Pic of the shims need for the drum to disc conversion
Old Apr 11, 2002 | 10:43 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Pic of the shims needed for the drum to disc conversion
I am almost finished with the conversion. The pic attached shows you how much/many shims are needed to get the caliper cage centered on the rotor. I am debating having a single steel shim made so I can get rid of the slew of brass ones that I have been slaving over to make... what do you guys think?
Attached Thumbnails Pic of the shims need for the drum to disc conversion-ds-shim.jpg
Old Apr 11, 2002 | 12:05 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Don't forger that the sliders on the caliper bolts are very forgiving so you just need to be close.
Old Apr 11, 2002 | 12:58 PM
Omega's Avatar
Engine: LS1 / LS3
I know that the calipers are able to move around a little bit. The rotor (when the lugnuts are tightened) fits very nicely inbetween the two sides of the caliper cage.
Old Apr 11, 2002 | 03:12 PM
Camaro_hunter_d's Avatar
Which conversion is that? the LS1 disk retro fit or what?....
Old Apr 11, 2002 | 04:22 PM
Omega's Avatar
Engine: LS1 / LS3
That would be the 1LE conversion.
Old Apr 11, 2002 | 04:29 PM
Na I'll stick with the easier LS1 rear disk...
Old Apr 12, 2002 | 10:19 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Just a reminder to anyone who may get confused (like I did originally):
Only disc brakes which use a carrier have to worry about this.
The 82-88 brakes don't have this issue (probably the ONLY good thing about them, LOL).
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Oct 3, 2015 12:43 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
