timing question
Old Apr 28, 2002 | 02:30 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
timing question
Hi everybody. I've seen a lot of posts on timing here lately, and most tend toward a 4* to 8* advance with a stock chip.
Well, I was one of those unlucky people that wasted $120 on the Thermomaster chip from Hypertech. Anyways, I know that the chip is supposed to advance the timing more than that of the stock chip, so I was wondering if it would even be worth it for me to play around with my base timing. I'm not sure what the advance goes to with the chip, I think I read 30* w/ the stock, so I would assume around 36* or so w/ the Hypertech. Anyways, any comments would be helpful. Thank you in advance, Roy
Old Apr 28, 2002 | 02:12 PM
NJ SPEEDER's Avatar
teh hypertech chip does not change your timing at all. it enriches the fuel a little, and very littel at that.
your factory timing will get intot he 30degree range some times, but not too often. you shoudl advance the base timing to 4 or 6 degrees and see a difference in performance. the timing table is so conservative that the car will not knock before the table runs otu of advance unless you are running crappy gas.
later
tim
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
