rear end
Old May 2, 2002 | 10:49 PM
Risk81's Avatar
rear end
I have a 3.08 limited slip rear end in my 89 TA 5 spd 305 with headers. I wasnt to go faster but I dont want to lose top end speed. I was thinking about getting posi and leaving it a 3.08. I dont have a lot to spend so getting gears is too much. I was wondering if a rear end out of a iroc or gta might have a 3.42 posi and be cheaper. Also if I do change my gears how much top end speed will I lose, and how much will my spedo. be off?
Kris
Old May 2, 2002 | 10:59 PM
iroc22's Avatar
You're speedo will be slightly off, all you need is a speed drive sensor from the car with the same gears as you.
A 3.42 car would be a manual TPI car (or 3.45 if it's a BW rear)
Posi=limited slip. Open diff is one wheel spinning.
Old May 2, 2002 | 11:26 PM
CNY89rs's Avatar
Car: 89 RS
Engine: 305 TBI
If you look in the post titled " just how fast can i go with everyones help??? "NJ Speeder tells how to get a rearend
from a six cyl. car with 3.42 and add the SLP posi. I think that's
what I'm going to do. I was thinking about going with 3.73 but
this seems like a very good idea, and way cheaper!!!
Sorry I don't know how to post a direct link to it.
Hope this helps
Brian
Old May 3, 2002 | 04:05 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i wouldnt open that thing up unless you were planning on getting gears put in it and a posi
Old May 3, 2002 | 04:44 PM
deadtrend1's Avatar
i got the 3.42 gears put into my bird with the T5 and SLP posi. It made me smile like McDonalds does.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
