holley tbi
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
holley tbi
how good is the holley tbi unit. is it beter than doing the tbi mods or the 454 tbi. the cash is not a issue i know nothing about burning chips and there is no one around me that i know of that can burn me a chip i just want my tbi 350 in my K2500 to spin to 5 -5.5 k with a good cam and intake. thanks guys
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
In response to your first question - yes, the holley is a great unit as far as i'm concerned. It flows more than enough for a mild 350 and as i've experienced, can support one up to at least 5,000 rpm (and thats with the stock ignition). If you're going with cam/intake swap, i'd do the springs at the same time. 5,500 is a lot of rpm for an otherwise stock motor (especially the bottom end). When you start spinning a sbc that fast, balancing and valve float becomes an issue. I'd never want to take a stock crank over 6,000 rpm personally. That's just me.
TP
TP
Engine: l98 and lo5
the motor or that is going in the truck is a 1989 350 4 bolt main out of a one ton truck it will have a set of iron eagle heads (180 cc intakes ports) a comp cam pure nrg cam and the rotating assembly is balanced with a st of KB pistons.
Engine: Justa three-fiddy
Transmission: t56
There was some talk some time ago that the injectors on the Holley were poor - but I also recall someone saying that they may now supply better (GM OEM) injectors. Is this correct?
Engine: l98 and lo5
yes the old ones where no good for higher fule pressur since then they went to the gm type so every thing is all better now
I know a guy with one in a van with a 383. He said it was a huge performance gain and well worth it. You can get them with 3 different injector sizes 55, 62, 85 lb/hr. you have to run an adapter unless you buy or make a 2" bore intake. Have you run it yet, I have a 93'Burban with a vortec 350, I want to run one just looking for feedback.
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
Glowsock
Sep 11, 2015 11:09 PM
