No more errors!
Old May 19, 2002 | 06:38 PM
Snowdog 91 Formula's Avatar
No more errors!
Okay this is what I did.
Got the timing dialed in... about 2-3 degrees adv TDC.
The idle is around 800 RPM....
When the idle was lower (that is, set around 500-550 rpm, I would always get the code 43 thrown at me)
Now that the idle is boosted up to that, no more errors are being thrown. I had to triple check to be sure, and I have been running the car for 4 days with the new setting. No problems whatsoever.
I suppose the computer doesn't like that cam very much below that idle range.
Anyway, it is running beautifully now. Thought I would pass this along if anyone else has a 2030 cam with a 350....
Or similar mods that I have.
It might help others if they have a similar setup to me. I'm sort of unique in my area, but others may be doing similar to my setup now.
Yeah! No more ECM errors.
Old May 23, 2002 | 11:11 AM
*S*
Still no codes being thrown! OMG! I'm too happy!
Old May 23, 2002 | 12:31 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I also have the 2030 cam and TBI.(hydraulic roller version)
Mine doesn't like idling below 800 either!
Actually seems happiest idling at 800-950, depending on the water temp.
Mine's also a 350.
Good to hear I'm not the only one.
Appreciate your passing along the info.
-Rich-
antman89iroc
36
Jan 31, 2016 08:42 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
