ok what cam
Old May 23, 2002 | 04:06 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ok what cam
out of these two cams which one is better for a 350 tbi with dart 180 cc heads
Intake/ Exhaust
Valve Adjustment 0 / 0
Gross Valve Lift 0.48 / 0.488
Duration At 0.006 Tappet Lift 258 / 264
Valve Timing At 0.006
Open /Close
Intake 21 / 57
Exhaust 68/ 16
These Specs Are For The Cam Installed At 108 Intake CL
Intake /Exhaust
Duration At 0.05 206 / 212
Lobe Lift 0.32 / 0.325
Lobe Separation 112
or
Intake/ Exhaust
Valve Adjustment 0/ 0
Gross Valve Lift 0.472/ 0.48
Duration At 0.006 Tappet Lift 252/ 258
Open Close
Intake 20 / 52
Exhaust 63 / 15
These Specs Are For The Cam Installed At 106 Intake CL
Intake /Exhaust
Duration At 0.05 200 / 206
Lobe Lift 0.315 / 0.32
Lobe Separation 110
on top of that which one would the computer like more
Old May 23, 2002 | 04:21 PM
NJ SPEEDER's Avatar
i would lean towards the first cam listed with teh 112degree lobe seperation. a little more lift, longer duration and a wider lobe seperation will make a bit more power and the wider lobe seperation will allow for more vacuum making the car a bit easier toi tune and much more pleasant to drive.
later
tim
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
