Flow direction of Fuel Filter, ASAP
Old May 25, 2002 | 03:58 PM
vjo90RS8's Avatar
Car: 2002 Z28
I just changed my fuel filter and i just wanted to make sure that i put it in the right direction, right now i have the flow arrow going from drivers side to passenger side (from fuel tank to engine i guess), is this the correct flow direction. I am confused because when i removed my old filter it had the flow direction in the other direction but i dont know if i flipped the fuel before looking at it, and i thought it would make more sense if it was coming from the tank to the engine. Am i right. THANK YOU for your help
Old May 25, 2002 | 05:13 PM
vjo90RS8's Avatar
Car: 2002 Z28
anyone, please!!
Old May 25, 2002 | 06:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the arrow should point towards the fitting on the line leading up to the motor. visually follow each fuel line to determine which it is.
Old May 25, 2002 | 07:32 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
it goes from drivers side to pass. side...u got it reversed
Old May 25, 2002 | 08:17 PM
vjo90RS8's Avatar
Car: 2002 Z28
the post says that i have it from drivers side to passengers side, so i guess that i have it right. THANKS
Old May 26, 2002 | 02:03 PM
vjo90RS8's Avatar
Car: 2002 Z28
ok, one more verification and i should be satisfied
Old May 26, 2002 | 03:13 PM
steve8586iroc's Avatar
vjo, you do have the filter on correctly. And as mentioned above by Demented, by following the path of the fuel which has to go thru the filter before going to the engine, the arrow will always point toward the engine which IS the direction of flow.
Steve
Old May 26, 2002 | 06:24 PM
vjo90RS8's Avatar
Car: 2002 Z28
thanks
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
