Tuning problem with vortec heads
Old May 26, 2002 | 11:52 PM
saus89's Avatar
I just finished installing a set of vortec heads on my 89 firebird. i had already installed a LT1 cam headers, exhaust, performer rpm intake, pulleys, coil, wires, and an openn element, as well as a thermomaster chip. before the heads the car ran great but now it runs very rough and at light throttle and full throttle it hesitates and starts to shake but smooths out at about 2300 RPM. At full throttle I can smell gas. Has anyone installed a set of Vortec heads on a TBI? Is the computer freaking out or could it be an ignition problem? A bad plug or wire perhaps. The tbi is stock except i have ported it and the fuel pressure has been turned up. Any suggestions would be appreciated
Old May 27, 2002 | 10:13 AM
Brent's Avatar
I'd start with mechanical things first. Re-check the valvelash, look for vacuum leaks, re-check timing, firing order, etc.
How does it idle? Put a vacuum gauge on it. Should read about 18-20inches and the needle should be rock steady.
Old May 27, 2002 | 11:05 AM
bills82z28's Avatar
check valvelash
Old May 27, 2002 | 11:22 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
check ignition too... take a crayon with the engine running and touch the exhaust headers one at a time.. I suspect you have a dead cylinder (the one that doesnt melt the crayon is the dead one)
Old May 27, 2002 | 01:12 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like a cylinder isn't firing. Might want to do what pablo said and if that doesn't help, pull the plug wires and check that each wire is making spark. It's simple, get an extra spark plug, ground the threads to the chassis and have a friend turn the car over, the plug that doesn't fire means you've got a bad wire.
Old May 27, 2002 | 03:44 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
if its caused by crossed wires it will still spark
Old May 28, 2002 | 01:56 AM
JPrevost's Avatar
Car: 91 Red Sled
That's a no brainer. Definatly check to make sure correct firing order but what it sounds like to me isn't a crossed wire and is infact just a cylinder not firing. If it was a crossed wire it wouldn't even run as well as you're saying it does.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
