Dual snorkel problem
Old May 21, 2002 | 09:16 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yeah, I know this is the TBI board, and yeah, I know I don't have TBI. Bear with me...
I converted my 84 sport coupe over to a serpentine setup, using parts from a 1990 TBI firebird, and now my dual snorkel doesn't fit any more. I can't even bolt the passenger's side scoop in place because the A/C lines are in the way. I searched a bit and didn't find any TBI cars that had the dual snorkel with AC. Any ideas what can be done about the AC lines? It cleared the compressor when the lines were off.
Of course, the AIR injection divert valve is in the way, but that's only staying long enough to pass emissions.
Old May 21, 2002 | 12:10 PM
JPrevost's Avatar
Car: 91 Red Sled
Don't use that snorkel, just route some other hose under the lines and down under the car to the front air dam or next to the radiator scoop. It won't fit, I've tried it before , not a big deal because the open element was better anyways. I did notice a huge diference in the intake sound with the dual snorkel on and eventually I'd like to put it back on.
Old May 21, 2002 | 01:07 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i have the dual snorkel, you have to use some ingenuity to route the hose,it basically does an immediate 90* turn downwards into another 90* towards the front of the car under the ac lines and above the stabilizer bar.............i then routed it to, well i cant tell ya that cause it even suprised the guys at airbox.com where i bought the box, he insisted it wouldnt work, i proved him wrong
Old May 21, 2002 | 01:09 PM
99Hawk120's Avatar
It's not the hose that's the problem. I haven't even gotten that far. It's the snorkel itself--the A/C lines physically occupy the same space that the scoop needs to go.
wasp's Avatar
oops, thats ramairbox.com
Old May 21, 2002 | 01:10 PM
wasp's Avatar
oh i see what your saying, yeah you need a box that the snorkels are 110* apart.........
Old May 21, 2002 | 01:12 PM
99Hawk120's Avatar
Noooo... not the snorkel on the BOX!
The scoop! The part that bolts to the front support and the coolant tank! Dammit, where's my pictures...
Old May 21, 2002 | 03:13 PM
RSRagtop's Avatar
You have an L69 HO aircleaner right? Most people gently bend the lines to clear, but I have never seen pics. I just went and looked at my car, I don't see how that would work. Maybe you could trim the end of the scoop shorter and route the hose under the lines. Doesn't sound fun anyway you look at it.
Old May 21, 2002 | 03:16 PM
99Hawk120's Avatar
Yep. Here's a picture of what it looked like pre-serpentine:
Old May 21, 2002 | 05:08 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
99Hawk, Is this the problem you're having?
Old May 21, 2002 | 05:10 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Another pic of the problem:
Old May 21, 2002 | 10:10 PM
esr92cam's Avatar
i avoided the problem
I took my good ol mitre saw and cut the scoop in half and fipped it over. You will only have worry about coolant tank thats and easy fix at the junkyard or a gatorade bottle.
Old May 22, 2002 | 08:10 AM
99Hawk120's Avatar
Tim, yep, that would be it.
Any suggestions? (aside from lose the AC)
Old May 22, 2002 | 10:39 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I've thought about having the lines re-fabbed to fit around the snorkel inlet, but I don't want to crack or crimp that manifold. I have a little bit of play in one of the hoses but not enough to get by. I'm still open for ideas too. I had an open element but I prefer a clean factory looking set up.
Old May 22, 2002 | 10:40 AM
99Hawk120's Avatar
I'm actually planning on hitting the yard to see if any other AC lines might be a better fit, myself. Other than that, I have no ideas.
Old May 22, 2002 | 10:42 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Keep me posted on how it turns out. Drop me a PM.
Old May 22, 2002 | 10:43 AM
99Hawk120's Avatar
Will do.
Old May 22, 2002 | 11:11 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I solved this problem by removing my washer tank and relocating the coolant recovery tank to the driver side. I also used a tank form an '86 which is smaller.
Bill
Old May 23, 2002 | 07:41 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Bill, could you post some pics?
Old May 23, 2002 | 07:59 AM
99Hawk120's Avatar
Being an 84, my car already has the smaller coolant tank--doesn't help much.
Old May 23, 2002 | 04:50 PM
azvolfan's Avatar
I can post the pics. It will take me a few days though. I will have to get my borthers digital camera. But I should be able to do it by this weekend.
Bill
Old May 23, 2002 | 04:55 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Thanks Bill. I'll keep an eye out.
Old May 27, 2002 | 04:03 AM
azvolfan's Avatar
http://albums.photo.epson.com/j/View...p=60913525&f=0
Old May 27, 2002 | 04:08 AM
azvolfan's Avatar
Tim,
I think I got it now. That was one of the dual snorkel. The right hose runs right by the a/c hoses. The coolant bottle was moved to the driver side and the washer bottle was removed. Here are tow more.
http://albums.photo.epson.com/j/View...p=60913536&f=0
http://albums.photo.epson.com/j/View...p=60913537&f=0
Old May 28, 2002 | 08:20 AM
99Hawk120's Avatar
That's pretty slick. Too bad I need both the coolant reservoir and the washer bottle. For the moment I'm running an open element. I'm hoping the dual snorkel will pass emissions and/or state inspection even with one snorkel missing (after all the thermac still will work since it's in the air cleaner assembly...
I'm also thinking about hacking up a TPI intake to fit an airbox of some sort. Won't be emissions legal of course, because there's no THERMAC, but it will be interesting to see how it works.
I am still going to try and come up with a way to get the dual snorkel to work without removing parts I need. I'm convinced that I need to get AC piping with a different routing to do it--I didn't have time to look when I was in the junkyard this time, I was too busy pulling parts I needed.
customblackbird
Aug 15, 2021 10:16 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
masonta
Sep 1, 2015 06:40 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
