New heads with LT1 cam
Old May 30, 2002 | 06:55 PM
RallySport92RS's Avatar
Im getting the LT1 cam in a week and i went into a performance shop to ask about the timing chain and valve springs (which is all i need to install it right?) and the guy told me that without new heads or head work, the cam wont work? is this true?
he also said without doing any other mods it might not fit or give me any difference at all. so far I have full 3inch exhaust from the engine, 3.73 posi, and k&N
Old May 30, 2002 | 07:09 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The cam will work fine. You wont get the full benefits of the cam with the stock heads, but Tim said that someone still picked up 4 mph using stock heads with just the LT1 cam.
4 mph is 4 mph any way you look at it
Old May 30, 2002 | 07:19 PM
iroc22's Avatar
The theory behind it, is you will suffocate the plenums if you run a longer duration cam with low-flowing runners. That's an old hot rodder thing when the cams were wild and heads horrible. The LT1 cam isn't nearly as radical as the cams that were being installed back then. So don't worry about it, the cam will wake up that sleeping TBI.
Old May 30, 2002 | 08:03 PM
these are the specs to the cam, will this work in my L03
DURATION LIFT (1.5) LIFT (1.6) LOBE
230 208 .450 .460 .480 .491 116
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
