rebuilding a 93 truck engine
Old Jun 5, 2002 | 01:27 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
i found an engine from a 93 truck. its a 350 and i wanted to buy it and rebuild it. this is the kit im goin to use to rebuild it.
Fel-Pro Gasket Set
Camshaft and Lifters
H/P Timing Set
Speed-Pro Ring Set
Main Bearings
Rod Bearings
Cam Bearings
Flat Top Pistons
High Volume Oil Pump
what else is needed to rebuild this engine.
Old Jun 5, 2002 | 04:09 AM
Audiman's Avatar
Rebuild
How many miles were on the engine?
Old Jun 5, 2002 | 11:05 AM
NTChrist's Avatar
Well, you're probably going to need a few head-related things, too.
Like new valvesprings, new valve guides, new valve stem seals.
If this rebuild isn't going to be a rush job, you can usually jump into it, and buy the little things as the time comes.
Old Jun 5, 2002 | 12:20 PM
Audiman's Avatar
Dont use the Lo3 heads off that motor, they suck!
Old Jun 5, 2002 | 12:53 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
thats not a LO3, its a 350. i was planing on getting that engine, send the heads out for a valve job, new valves, seals, valves, i jsut wanted to know if i needed anything else than listed above.
Old Jun 5, 2002 | 03:37 PM
Audiman's Avatar
Heads
If it is a 93 350 out of a truck it can have either the heavy duty heads or swirl port heads. The swirl port heads are unanimous with blowing head gaskets and they dont flow that great. I dont know what a camaro eng. comes with as far as heads bu these are some of the crappiest heads chevy built. You would definitely need them surfaced.
junkcltr
Aug 2, 2019 11:12 PM
ezobens
Aug 19, 2015 10:29 PM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
