Code 44
Old Jun 26, 2002 | 07:03 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Code 44
What is code 44? I don't have my booklet with me and can't remember what it is. Little help and explanation would be greatly appreciated.
Old Jun 26, 2002 | 08:32 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I think it's either lean or rich. Code 43 is the compliment. I just can't remember which! I guess that doesn't help you all that much...let me see what I can find on Google.
EDIT: Ok, I was wrong. Code 44 is lean exhaust, code 45 is rich.
Check the O2...what mods do you have?
Old Jun 26, 2002 | 08:37 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
yeah ur right, its for lean conditions, but my fuel pressure is at 14psi. I wonder if my fuel filter needs to be replaced or something or my injectors need to be cleaned.
Old Jun 26, 2002 | 01:17 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I got a 44 code after I did my motor swap and it turned out to be that I never hooked up my vaccum line for the MAP sensor cause I thought it was the vaccum for the EGR at the time and I didn't have EGR so I left it hanging. So turned out that the ECM wouldn't sense any load so it wouldn't had any fuel. Don't know if you might have a similar problem but it might be a start.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
