What size?
Old Jun 27, 2002 | 01:56 PM
The Greek's Avatar
Car: 70 Nova SS
Transmission: TH350
What size open element?
I am planning on buying a K/N drop base open element air filter with the Xstream top. What size height will the hood still clear with. The 2 3/4 or the 3 1/8. I would imagine anything taller than that wouldnt fit.
Old Jun 28, 2002 | 12:25 AM
Tas's Avatar
Tas
1. Get a non drop base.
2. 3" should be fine.
Old Jun 28, 2002 | 02:16 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
If I had to do it over again I'd get a non drop, but I cant seem to find just the base. Maybe a swap meet.
14x3 is what you're looking for.
Old Jun 28, 2002 | 11:24 AM
3five0's Avatar
If you are going to go with an open element you should get a hood. Either a cowl hood or a ASCD hood because I ran an open element for a while and the heat from my engine and radiator just slowed my car way down. You should check out a ram air box at www.ramairbox.com or go with the intake off of a truck or L69 HO dual snorkel, but don't forget the cool-air tubes.
Old Jun 28, 2002 | 07:05 PM
The Greek's Avatar
Car: 70 Nova SS
Transmission: TH350
Well how much of a differnce is a drop base vs a non-drop base? Why is getting a non- drop base better?
Old Jun 28, 2002 | 07:08 PM
Tas's Avatar
Tas
The non-drop base lets you take out the spacer ring. Think about it: Isn't lifting up a drop base air cleaner with a 1"+ tall ring stupid?
daxi?
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
