Rich/Lean - What's the right fuel pressure???
Old Jun 29, 2002 | 09:36 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Hi everyone - ok, I'm running about 12-13psi for fuel pressure and the car's running great lately (starts right up - pulls thru 5,000 rpm real strong) but i get a few puffs of smoke on start-up until the car goes into open-loop and the O2 sensor takes over - my plugs are a little sooty on their outside rim, so i know i'm running rich - but how do i solve this? Is it unsafe to go too low on fuel pressure? (like at the risk of not-enough-fuel-pressure at high rpm?) Has anyone else encountered this? I'd appreciate any feedback, its like the only bug i've got left to work out.
Tyler
Old Jun 29, 2002 | 10:14 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
How old is the engine? Those few puffs of smoke on startup cvould be the oil that got past the vavle guide seals burning off.
Old Jun 29, 2002 | 12:34 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
brand new - i put the motor together myself (thats not the problem) - I'm certain its a matter of running rich - i just need to know how to go about fixing it - i've got the 305 computer still too
Old Jun 29, 2002 | 03:53 PM
Car: 88 Camaro SC
Engine: SFI'd 350
what injectors are you using and where did you get them? My engine runs so lean its crazy. Even with the fuel pressure up all the way the o2 sensor output is almost nill when i give it gas. I ahvnt even broken in the cam yet because i dont want to damage the heads or pistons.
Old Jun 29, 2002 | 03:55 PM
Car: 88 Camaro SC
Engine: SFI'd 350
oh.. if you dont have winaldl, get it. Its free and the cable is easy to make. Winaldl will tell you if your rich or lean by directly putting out the o2 voltage output as a readout. No need to use a volt meter.
Old Jun 29, 2002 | 05:56 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Yeah winALDL is great but ever since that darn swap the stupid ALDL conector dont do squat, it wont even let me pull codes, but anyways I vote for the winALDL also.
Old Jun 30, 2002 | 09:38 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
well, i've downloaded the software already - i've got to get a cable made - but my problem is knowing how far down i can go on my fuel pressure - is it safe to just keep turning it down until the motor isn't rich? I need a 350 comp. lol
Ty
Old Jun 30, 2002 | 10:34 AM
rsc350's Avatar
Car: 92 Camaro RS
The computer is the same no matter if it is a 350/305 just a different chip. If you got a 305 chip, change it and see if that helps before you go messin with puel pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
