Removing AIR, What to do with electrical connector?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am removing my AIR and I am not sure what to do with the plug that comes out of that diverter black box thingy over the passenger side manifold. DO I just unplug it and let it hang? Will it throw a code?
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
yea you should be able to zip tie it to something. Just make sure its outa the way of the header/manifold (like mentioned above) and outa the way of the belt.
Car: 91 Formula
Engine: 305 TBI
Ditto Chuck. I put some ribbed plastic wire wrap (the stuff around your wire bundles) around the two connectors (facing one another) and zip tied this bundle to an A/C pipe. No codes.
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
