Vortec Swap and keeping EGR
Old Jul 14, 2002 | 01:58 PM
19TA85's Avatar
I just bought a pair of vortec heads off ebay for a price I couldn't pass up. I did this before really looking into the swap process onto my 305 TBI. From what I've read now it seems like maintaining the EGR is a problem. Is there some way to get around this? This car absolutely has to be smogged.
Thanks,
----Ryan
Old Jul 14, 2002 | 02:34 PM
Tas's Avatar
Tas
looks like you'll have to get the Vortec TBI intake and cross your fingers they won't want a C.A.R.B. number for it. Maybe paint it black like stock.
http://www.sallee-chevrolet.com/Chev...ortec_TBI.html
Old Jul 14, 2002 | 07:26 PM
jagone's Avatar
there are vortec intakes that have EGR provisions, then you just have to plumb a line off one of your exhaust manifolds/headers to the EGR valve. Look at the 330HP motor at go auto center, they have the tube listed in the accesories at the bottom.
[url]http://www.goautocenter.com/330hp_vortec.htm
Old Jul 14, 2002 | 08:34 PM
steve8586iroc's Avatar
I read an article on swapping a ZZ4 into a 86 Camaro that was originally equiped with an L69. SuperChevy did the swap with a complete retrofit package from GM, they stated that it wasn't nessasary to use egr as the ZZ4 has no provision for it. This was also done in Ca. You might want to check into it yourself. If you want to read the article go to SuperChevy's web site.
Steve
Old Jul 14, 2002 | 08:36 PM
Tas's Avatar
Tas
Originally posted by steve8586iroc
I read an article on swapping a ZZ4 into a 86 Camaro that was originally equiped with an L69. SuperChevy did the swap with a complete retrofit package from GM, they stated that it wasn't nessasary to use egr as the ZZ4 has no provision for it. This was also done in Ca. You might want to check into it yourself. If you want to read the article go to SuperChevy.com .
Steve
That's for carbs and the "package" is expensive and out of date.
Old Jul 14, 2002 | 08:39 PM
Tas, you are correct, but wouldn't emissions requirments be the same?
Old Jul 14, 2002 | 08:45 PM
Tas's Avatar
Tas
its hard to say. If you're using a carb intake(for example) with the C.A.R.B. E.O. number on it they might let you use the part. I've never asked a smog tech referee so I can't say really. As for putting a 350 where your 305 is, they can't look inside your engine so as long as you pass the sniffer and have smog legal parts for the visual inspection it should be cool.
Old Jul 15, 2002 | 12:21 AM
ZRATED's Avatar
I have that GM vortec TBI intake up for sale in the thirdgen clasifieds. I bought it off some guy that took it off after a few weeks becuase the tbi did not like the cam he was running and decided to throw in a carb. This intake is like new and is in perfect condition send me and e-mail if you are intrested in it.
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
jharrison5
Aug 19, 2015 05:53 PM
