Carb to TBI adaptor?
Old Jul 15, 2002 | 08:46 PM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
Anyone using a carb to tbi adaptor on a factory carbed 305? I'm looking to swap in an 86 305 into my S-10. Yes its no F-Body but I figured since the 305 is a very common F-Body engine you guys could help. So yeah, any help would be great!!
Old Jul 15, 2002 | 08:50 PM
Snowdog 91 Formula's Avatar
Intake and TBI
Just use the TBI stock intake and TBI unit.
OR
Do something like I did
Of course modifying an S-10 to a Firebird might take a little work!
Old Jul 16, 2002 | 09:22 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm looking at swapping the old 305 TBI motor from my 92 Camaro RS into my wife's 91 S10 Blazer. Actually the best source of info on this I've seen is from JTR (Jags That Run) a company that usually specializes in small-block chevy Jag swaps.
http://www.jagsthatrun.com/
They sell a book on Swapping sbc into S10's and another book on GM TBI/TPI motor swapping. Both are loaded with info.
According to them, the easiest swap for an an S10 is a TBI F-body motor. The stock manifolds are the best fitting, and if the S10 came with a 4.3 TBI it's almost a direct swap. The wire harness even works, just change the chip in the computer and bring everything else over from the F-body.
I hear the cheapest TBI adapters for carb intakes are available from P.A.W. in Southern CA.
Hope this helps.
-Rich-
Old Jul 16, 2002 | 06:25 PM
Nate Hanson's Avatar
I have a Edelbrock TBI Performer Manifold for sale. I just took it off my S10 actually. $125 plus shipping.
Nate
Old Jul 16, 2002 | 07:13 PM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
thanx for the responses guys.. The problem is that a TBI intake manifold wont bolt up to Carbed heads.. so if I change the intake I have to change the heads. Otherwise I'd just do that. So the Carb-->TBI adaptor is the easies way to go.
Old Jul 16, 2002 | 07:49 PM
Tas's Avatar
Tas
1. the 4 center intake bolts have different angle. You can open up the holes on the intake to match.
2. do a serarch for the adapter.
3. www.turbocity.com has some
4. www.holley.com has some
5. people have made their own.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
