tbi wires
Old Jul 17, 2002 | 06:41 PM
88NOSTA's Avatar
tbi wires
the guy that had the car befor me cut the wire's for the injectors can someone help me out and post a pic or tell me the wire placement
Old Jul 20, 2002 | 04:59 PM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
Do you have the wiring harness?
If so match up the wire colors, otherwise they are as follows:[list=1][*]Injector #1 (Left Hand) Lt. Blue and Red.[*]Injector #2 (Right Hand) Lt. Green and White.[/list=1]
Each injector has two wires. The Red and White wires share a common fuse (possibly the Ignition Fuse). The Lt. Blue and Lt. Green wires come dirrectly from the ECM. Use a good quality conector to hook up your wires (Weather Pack connectors are used on GM cars as standard equipment and are avialable from your dealer in two four-pin designs).
If you hook something up wrong is wont hurt your ECM or injectors. If either one or both are not working check your fuses first. They should fire alternatingly.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
tero
Aug 15, 2015 02:47 PM
