new to TBI
Old Jul 17, 2002 | 10:38 PM
rkm's Avatar
rkm
new to TBI
I have a 1988 chevy 350 TBI motor that needs rebuilt I was going to go .030 over and a slightly oversize cam. Does my prom need to be reprogrammed or should it be ok. Thanks
Old Jul 18, 2002 | 08:12 AM
BillD91RS's Avatar
What prom is in there now? Is it a stock prom from a LO3 motor or is it from a LO5?
Old Jul 18, 2002 | 07:13 PM
rkm's Avatar
rkm
The motor I am installing is from an 88 chevy truck as well as the computer, it is going in a jeep. All of this is new to me another site said this was the place to go for TBI help. Is there a certain chip I should look for?
Old Jul 18, 2002 | 07:37 PM
Slade1's Avatar
As long as the cam isn't significantly larger, it should be alright. A medium range cam although higher in the medium range, is still a medium range cam. You may only have to do some tuning, advance a little to adjust, but not a new chip. If you go with a hot cam, then a new chip is necessary.
With the extra bore, you will end up running significantly hotter than before. So just a heads up to make sure your cooling system is up to task.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
