Friend's 92 RS horribly failed CA emissions. He has changed the EGR, EGR Vaccum solenoid, Cap/Rotor, plugs, wires, O2 sensor, MAT Sensor, fuel pump, fuel pump relays, oil pressure switch, rebuild throttle body, no vaccum leaks, Edlebrock Headers, High Flow Cat, 3"intermediate pipe, and flowmaster muffler.
Here is a brief run down of the #s
HC(PPM) = 252 (MAX 108) @15
217 (MAX 83) @ 25
NOx = 1888 (MAX 1020) @ 15
1486 (MAX 880) @25
CO2 = 12.1 @15
12.2 @ 25
CO% = .43 (MAX 0.71) @ 15
.22 (MAX 0.58) @ 25
Please give me some ideas what to do/change next, thanks!
217 (MAX 83) @ 25
1486 (MAX 880) @25
CO2 = 12.1 @15
12.2 @ 25
.22 (MAX 0.58) @ 25
egr or runnign very lean will cause nox to be high, it can also be a sign of too much base timing.
hope this helps.
later
tim
hope this helps.
later
tim
Thanks for the suggestions NJ Speeder, the additional problems are that his RS is appearently running way to rich!
And his timing is set at 0 degrees
And his timing is set at 0 degreesMember
Advance the timingOriginally posted by 8T8IROC
And his timing is set at 0 degrees Arctic White 91 RS
close
Clean oil
stock temp stat
Get the car hot before the test. Get the temp up to about 220 then cut the car off and it sit. It should still be nice and hot when they test.
stock temp stat
Done all that as well, car doesn't get to hot (temp gauge indicates 160-180) he has changed the oil and the thermostat, still no luck
