Electric Fuel Pump Question
Old Aug 6, 2002 | 08:37 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Today I was passing a truck when my engine died. I coasted to the emergency lane and tried to start the car but, it wouldn't start. The engine would crank over and the battery voltage was good so I looked at the fuel gauge to make sure I had fuel and it looked sort of low but not empty. I wanted to know, when the electric fuel pump dies does it just stop working Immediately or does it show signs of wear? Also, if the fuel pump relay was bad would this be the reason my engine just stopped?
Old Aug 6, 2002 | 10:11 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
yep... a fuel pump or the fuel pump relay can die unexpectedly. If you dont hear teh pump come on when you turn the key to the on position, the fp or the fp relay are most likely bad.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
