Fuel Pressure Gauge and Engine Heat
Old Aug 10, 2002 | 12:19 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I've been reading other posts about Inaccurate or Fluctuating readings of Liquid Filled Fuel pressure gauges that are mounted in the engine compartments due to engine heat. I want to know if even though the gauges Fluctuate because of the heat, is the Actual fuel pressure still the 12psi that it reads when the engine's cold? In Extreme Engine Heat my Summit Gauge shows fuel pressure readings as low as 7.5 psi but, the engine still runs fine at all times.
Old Aug 10, 2002 | 03:29 PM
JR305's Avatar
I would say it is the 12 you see when the engine is cold.
Old Aug 10, 2002 | 10:00 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
That is correct, the actual pressure remains constant. It's just that the fluid in the gauge and/or the gauge line starts to try to expand as warm fluids do. As they do expand the gauge shows less difference between the actual fp and the pressure of the fluid in the gauge. The gauge shows the pressure difference between the two fluids.
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
