egr delete
Old Aug 11, 2002 | 11:16 PM
sslee's Avatar
egr delete
If I put a plate under my egr valve will the car run normall or does the computer have to have the egr to work right.
Old Aug 12, 2002 | 12:48 AM
iroc22's Avatar
Read the 'lowdown on EGR' within the tech section on the main site. It will tell you whats up.
Old Aug 12, 2002 | 01:23 AM
NJ SPEEDER's Avatar
the easiest way to fake out the ecm is to take a check valve and just stick it onto teh vacuum line that used to lead to the egr valve. when the computer goes to pull the egr open it will open the check valve and think it opened the egr
later
tim
Old Aug 13, 2002 | 06:49 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
why would you want to do this
Old Aug 13, 2002 | 07:18 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Never stick a check valve in the egr line (there is no feedback from the egr to the computer, there is only an output to the egr from the computer, this is an open loop process) so you might as well just unplugthe vaccum line to the egr and letting it hang there, but don't do either of these things. Regardless of what is physically happening in terms of the egr, if the computer thinks its at 100%egr (even if it isn't) it makes changes to your fuel and timing (adds about 6 deg). If you just unplug your wires from the egr unit, this will disable egr, it will give you an error code though. All this said the real way to disable egr is to program it into the prom, with a custom chip.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
