Is anyone using the weiand 7525 manifold?
Old Aug 15, 2002 | 10:34 AM
bigman's Avatar
That's the single plane with the EGR provision.
Dan
Old Aug 16, 2002 | 01:04 PM
Dex's Avatar
Dex
yes
Old Aug 16, 2002 | 02:38 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Is anyone using the weiand 7525 manifold?
Best street single plane I ever used.
Old Aug 17, 2002 | 10:13 PM
alohamike's Avatar
Grumpy,
But are you still using it? Any fitment problems to be aware of? Previously you've recommended single plane manifolds for TBI, correct? If I were changing manifolds from stock for the first time, would this be one of your top choices?
Thanks!
Old Aug 19, 2002 | 08:53 AM
bigman's Avatar
Yeah, what they said. Is it too much for a 305 even with a cam, what about with the stock setup? Where'd you buy it, the only place I can find it is dougherbert.
Dan
Old Aug 19, 2002 | 10:08 AM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
A buddy of mine is using it
granted, thats an 11 second car without the juice. And its a 355 with 11:1 compression. I think that intake would be WAY too much for a mildly modded motor. IF you have a BIG exhaust and some kick @$$ heads that cost you a fortune, I think that it would be a good intake, but other than that, I don't think that its worth it.
That's just my $.02
Old Aug 21, 2002 | 01:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by alohamike
Grumpy,
Thanks!
On a 305 might be a little much.
7546, might be a little better. I'm not possitive on the number, but it's a low profile, single plane with a removeable divider. And it worked OK on a 305 with only high ratio rockers.
I had the 7527 on an 84 Firebird, K+N dropped base, 2.25 cleaner, and it jussssst cleared.
The 7525, did wind up on a boat.
Ski boat that is, if you're familiar with how much drag a prop is, and add a couple skiers, when I say it comes off idle well, that is a good manifold. While a dual was a tic cleaner, just off idle the 7525 added like 7 MPH on top.
Old Aug 22, 2002 | 09:02 AM
bigman's Avatar
The bummer is that the 7525 comes with EGR provision, the other one doesn't 7546. I'll probably hold off for a 350 to put it on. I wonder if it'd be possible to create a plenum divider. Seems like an aluminum plate and some high-temp RTV would do the trick.
Dan
Old Aug 22, 2002 | 01:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
RTV dissolves in gasoline.
RBob.
Old Aug 22, 2002 | 02:17 PM
alohamike's Avatar
not having seen a 7525, what makes it too much for a 305? Everyone complains that these engines don't flow very well. I just read the Car Craft 305 buildup from 1999 and they used a single plane with excellent results, preferring it over the dual plane. It pulled 20in of vacuum with the stock cam, just like the stock manifold.
So, is the corporate thinking of the board that dual plane manifolds remain the best choice for TBI applications? I don't want to beat a dead horse, just trying to satisfy my curiousity by asking my much more experienced Gen3 brothers.
Mike
Old Aug 22, 2002 | 04:22 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
It would seem overkill on a stock heads/cam LO3. The power band is to like 2,000 - 7,000 aint it?
Add heads and a pretty big cam and you'd be cookin with that manifold, but I dont know how high I'd rev a stock bottom end LO3...
Old Aug 22, 2002 | 04:37 PM
bigman's Avatar
OK, JBWeld
single plane versus dual plane. A single plane manifold typically though not always has larger, shorter runners and a larger plenum. This allows it to feed the higher demand that higher rpm requires. However, at low rpm, the vacuum signal is less and the inertia of the air fuel mixture is high compared to a smaller plenum and smaller runners, and less fuel is able to get into the cylinder than if things were smaller. I hope something here is clear, because I know what I was trying to say but I don't know if anyone else will.
Dan
Old Aug 22, 2002 | 05:40 PM
alohamike's Avatar
so what's the deal with the newer design dual planes that cut out part of the divider to allow the cylinders to draw from both sides of the carb/TBI? It's not a true open plenum but it isn't a true dual plane either.
sailtexas186548
Feb 17, 2017 03:07 PM
JSDaddy189
Sep 26, 2015 03:50 PM
TexasMaro
Sep 15, 2015 06:50 PM
R3500
Sep 8, 2015 10:12 PM
