part #s
Old Aug 17, 2002 | 06:13 AM
topher's Avatar
part #s
i need part#s for a tbi 350 injectors, ecu, knocksensor, IAC, throttle position sensor, and are any of them the same on a 305 tbi setup on 1989 rs. also is there a big difference in the intake and throttle body size between the two
Old Aug 17, 2002 | 02:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
you probably want to get the 65 pph injectors and a prom for the police package (9C1 i believe). Youll also want to get a new knock sensor and est module for a 350 also. I got my borg-warner knock sensor for 45 bucks down at pep boys. Everything else is pretty much the same. I dont know all the PN's but im sure someone else can give them.
Old Aug 17, 2002 | 11:58 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
The part numbers as you ordered....
350 injectors ----------------(#17112493)
350 ESC module ------------(#16128261)
350 Knock Sensor ----------(#10456288)
If your car is an automatic, you should get a custom chip off of a police caprice package 91C.
Good Luck, eh!
Old Aug 18, 2002 | 12:00 AM
Car: 92 Camaro RS
The others....
Use the same ecm, just get a chip for it.
TPS is same
IAC is same
Any questions, just email me RSCamaroGuy92@yahoo.com
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
