open element question
Old Aug 20, 2002 | 11:26 PM
pardonme2711's Avatar
what should i do with the iat senseor ne way? i just quick tied it out of the way should i maybe put it into the open element? What does it do ne ways?all i did wa set the open element system on top of the ti i didn't put ne parts i took off back on, should i have?
Old Aug 21, 2002 | 05:14 PM
Ratstix's Avatar
ouch, that hurts my eyes to read that. please try to type better.
but anyway. the IAT sensor is to send the temperature of the air going into the engine to the ECU. you should drill a hole in the bottom of your open element and install it.
as for the valve cover breather, remove the hose and get a filter for it.
and the vacuum line that went from the TB to the air filter housing... just remove the hose and plug the port on the TB.
and Voila, your done.
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
