Modding the RS
Old Aug 25, 2002 | 03:12 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Modding the RS
I have a 91 RS 305 5-speed Vert. So far I have just put on an open element and catback system. Now I really want to mod this thing and get some more power out of it, but I cannot do any of the work for any big jobs. Let's say I have about 500 bucks to spend on it, what would u guys suggest I do next if I have to figure in what I'm going to have to pay for labor??
Old Aug 25, 2002 | 03:23 PM
RallySport92RS's Avatar
I bought an LT1 cam for 40 dollars US, and it cost me another 400 canadian to install it with new springs, lifters, waterpump, and timing chain. that was a good mod.
you might be able to do gears for 500 dollars as well.
Jesse
Old Aug 25, 2002 | 03:31 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hey man, I made a website just for people like u that are wanting to mod there 305 TBI's. I have part numbers, pictures, install instructions, do's and don'ts and other good stuff on it. Its the second site in my signature. Just click on a topic and start to read.
Old Aug 25, 2002 | 04:43 PM
BronYrAur's Avatar
Engine: 305 TBI
Thanks a lot for the replies guys. That's a great, informative site you've got there 91bird305, thanks for pointing me to it. These labor charges are killing me though. Just out of curiosity, how hard is it really to swap in a new cam. I only have standard tools and most of my knowledge is simply knowledge not any experience. The most work I've done is putting on a catback and open element. Just wondering how hard it would be for me to put in a cam?
Old Aug 25, 2002 | 04:53 PM
JR305's Avatar
For a beginner I would say pretty difficult. It took me around 4 days of work to swap my cam, but I also did the heads and intake.
Old Aug 25, 2002 | 05:23 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
RallySport92RS,
I was just wondering how much the LT1 cam helped you, and if you have any et's. Many people do the swap but then never actually let us know how much it helped. I've had the cam waiting to go in, but then I saw one guy post that he only gained .2 sec off his et after the swap-in which case I don't think it would be worth it.
Old Aug 25, 2002 | 07:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Great website you've made.
Easy to understand for any newbie, and educational at the same time. It's nice to see people that have the time and knowledge to design and host a webpage like that (and that also includes the people of thirdgen.org) pass their knowledge onto others.
Now after all the compliments I've got 2 things that you need to address. I'm only saying these to help you help others, no flame intended, OK?
1. You mention in the "Spark Plug Wires" section that it's best to have "high resistance" wires to carry the spark farther. That's incorrect. You want the resistance to be as low as possible. Kinda like you want the resistance in the exhaust system to be as low as possible.
2. You made no mention of a lower temperature fan switch that is needed to take advantage of the lower temperature thermostat that was just installed. You gently touch on it in the "Computer Chip" portion, but with our cars, the chip has nothing to do with the fan kicking on. It's all governed by the fan switch. The computer only controls the fan in TPI cars, and IIRC, it's only the secondary fan.
Again, no flame intended, just trying to help you help.
AJ
Old Aug 25, 2002 | 07:46 PM
r90camarors, I don't have any ET's because the nearest track is about 2 hours away.but i can tell you that there was a noticeable difference in performance. I lost a little bit of low end torque because the torque curve got moved up in the rpm range but the torque at the higher rpm's is way better then stock. I'd suggest doing an intake with the swap. I didnt but have talked to a few people that did and they say it helps quite a bit as well.
Also if you do it, make sure to adjust your fuel pressure, after I did this I got some of the low end torque back.
Old Aug 25, 2002 | 09:46 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
AJ
WHAT THE F-CK! IF YOU THINK YOU KNOW EVERY G0D DA-M THING ABOUT CARS THEN YOU MAKE A F-CKIN SITE THEN YOU ***** LOVIN GRANNY SHIFTIN 4 BANGER TALKIN MOTHERF_CKER!
Just kidding.
Yes your absoutley right, its low resistence, it must have been a late night when I was writing that up. LoL. Thank you very much, and I will also make a section for the fan switch. It will all be fixed by tommorow. Thank yas very much yas.
Old Sep 3, 2002 | 11:09 PM
FLYNLOW92rs's Avatar
91Bird305,
How much was labor for the Posi Unit and gears to be installed????
Old Sep 4, 2002 | 04:47 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Originally posted by FLYNLOW92rs
91Bird305,
Normally costs about $100 to get it done on the side.
Old Sep 4, 2002 | 09:12 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
91Bird305,
Actually you will need the shims and bearings replaced when you do so. They are usually 60 bucks. Then labor usually costs around 140-180 bucks depending on where you go. I actually have heard of people trying to charage people up to 500-1000 bucks just to change out your gears and differential...complete rip offs. Just be careful and shop around if your gonna have a shop do it. I would look around on your local message board (if you have one) for maybe a local car ethusiast to do it for you. They will charge you maybe 100 bucks and a 12 pack.
Old Sep 4, 2002 | 09:21 AM
Slade1's Avatar
After reading your site, I finally figured out why I could never get rid of the f-in whine in my gears...
I ended up spending on 2 shim kits trying to get rid of whine in my gears having to settle for a quieter whine...
First time around it was louder than hell, second time reduced, but noticable at different loads.
I have to say though putting in gears were a hell of a lot easier than removing headers... damn a/c makes things hard as hell.
Old Sep 4, 2002 | 10:55 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Glad my site could help.
Yeah gears aren't to bad if u have the right tools and know what u are doing. Good idea to add posi additive too.
Old Sep 4, 2002 | 11:05 AM
Slade1's Avatar
Think a posi additive would help on an open diff to cut down on whine? I've lived with it for 5 years now, just learned to ignore that sound really...
Old Sep 4, 2002 | 11:42 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
my moto is if your hearin your rear whine , your stereo isnt load enough or you dont have enough speakers.
Old Sep 4, 2002 | 12:04 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Posi additive I don't think would really matter with an open differential but I could be wrong.
As for the stereo comment....the audio forum is around the corner...you can drowned out all the engine knock and gear whine u want over there, lol.
Old Sep 4, 2002 | 12:24 PM
Slade1's Avatar
Whine's no big deal to me, just got my hopes up that I could get rid of it... oh well. I'm not into the whole stereo supersystem in the car deal, I prefer my home equipment a lot better and to get sound like that in my car I'd have to spend a fortune...
Old Sep 4, 2002 | 04:23 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I agree but I have to get a CD player sometime soon...i can't stand the radio and cassette tapes.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
