Injector spacer (not TB spacer)...
Old Aug 29, 2002 | 01:17 PM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
Does this raise everything, including the air filter assembly, or does it jsut raise the pod? I would like to get some more space in there, but with the open element I have, it touches the hood blanket as it is.
Thanks!
Old Aug 29, 2002 | 02:28 PM
dreamsbird's Avatar
It just raises the pod
Old Aug 29, 2002 | 10:21 PM
TBI305Camaro's Avatar
How does raising the pod help anything?
Old Aug 29, 2002 | 10:58 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
By raising the injectors further from the bores, it allows more airflow. Plus, it is said that a better cone can be formed.
Old Aug 30, 2002 | 10:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the same can be achieved using washers instead of a spacer. Just put the washers between the tb and the pod and put the bolts through the washers. Not only that but you can alter the hight as much as the fuel fittings will allow. I did it and it cost me nothing.
BumpaD82
Feb 26, 2016 02:57 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
