black smoke
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Rich.
The computer's programmed to run a little rich at WOT, but I've only seen black smoke (and very faint at that) under acceleration. If you've got it coming out just reving it up at a stand still, that's a little uncommon.
Check the spark plugs. They'll tell you more.
AJ
AJ
Car: 89 Camaro RS
Engine: 355 TBI
im also getting a code 15, witch is low temp at the coolent temp sensor. Some one told me that will make it run rich, i replaced the CTS and the sensor that turn's the fan on but i havent replaced the one between 1&2. plus my fan wont come on unless i turn my air on.
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
CTS will definitely make it run rich. Also no thermostat or one that is not working properly can keep the car from going into closed loop and thus be rich. The stock fan switch doesn't turn the fan on until over 200 degrees so you may have never reached that temp it your having a thermostat problem.
Car: 89 Camaro RS
Engine: 355 TBI
but i have a brand new superstat 195 in the car and the gage runs at 220. but it gives the code 15 the car is reaching the temp it should be. but something is wrong with it
TROUBLE CODES
15. Low temperature indicated at engine coolant temp. sensor
Straight from here.... https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
It could just be the sensor going out. IIRC, The one that shows the temp. at the gauge is a different sensor, so the gauge won't show the problem.
AJ
AJ
