Altitude change : WinALDL data help pls
Old Sep 14, 2002 | 10:09 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Well, I moved from Wisconsin (~300 ft) to AZ (~1500 ft) at ASU and my car definately does not run like it used to. It's slower and it has a major difference in sound. I switched my chip from a Jet Stage II chip to the stock one (assuming that it was running rich due to less air, but I never logged this). It runs better now, but not as well as I'd like. I run 91 Octane mobil gas currently, and this data was taken while driving around phoenix on various onramps and from stoplights. Some are full throttle, some are part, I really don't know which is which without looking at TPS which seems a bit shoddy. As you can see there are a small number of knocks, but I don't know how to read this (knocks per second, knocks per interval, or just knock count overall). My timing is not advanced (that I know of) at all except for what the stock chip does for it, but I haven't checked it to see whether or not the previous owner messed with it. Now, there might be a dent in the bottom of my cat, but I have to check again (which might explain the change in tone of the exhaust, but pretend I didn't tell you this). Can anyone find anything wrong with my car from these (other than the fact that some say I was going 120 when I never got over 80).
Here they are:
http://www.geocities.com/machowalkcl...me4thcoast.xls
http://www.geocities.com/machowalkcl...artofthird.xls
http://www.geocities.com/machowalkcl...tof2ndfull.xls
http://www.geocities.com/machowalkcl...of2ndfull2.xls
http://www.geocities.com/machowalkcl...tof2ndpart.xls
http://www.geocities.com/machowalkclub/2ndfull.xls
http://www.geocities.com/machowalkclub/blm1.xls
http://www.geocities.com/machowalkclub/blm2.xls
http://www.geocities.com/machowalkclub/idle.xls
http://www.geocities.com/machowalkclub/mixeddriving.xls
http://www.geocities.com/machowalkclub/whatthehell.xls
http://www.geocities.com/machowalkclub/whatthehell2.xls
http://www.geocities.com/machowalkclub/whatthehell3.xls
http://www.geocities.com/machowalkclub/whatthehell4.xls
http://www.geocities.com/machowalkclub/whatthehell5.xls
http://www.geocities.com/machowalkclub/whatthehell6.xls
P.S. what the hell is for when the speed sensor is on crazy pills
Thanks a lot
Old Sep 15, 2002 | 12:54 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Anyone , please?
Old Sep 15, 2002 | 01:54 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Tyr running at 4300 ft like me, when I go down to 2300 I feel way more power.
Old Sep 16, 2002 | 12:19 PM
JPrevost's Avatar
Car: 91 Red Sled
Everything looks normal to me except for the speed.
The reason you don't have any power is because the air is so thin you aren't able to get much air into the motor. You should notice a big difference in performance, just look at the guys that drag race where you're at and then look at the same cars running at sea level tracks.
Old Sep 16, 2002 | 06:01 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Thanks a lot man
I'm worried about the knock counts. I have the stock chip in, with no added base timing. Would it be ok to advance it a little you think.
I plan on advancing it 2 degrees at a time and seeing what happens, but when should I stop?
Thanks a lot
tbone
Old Sep 16, 2002 | 07:14 PM
JPrevost's Avatar
Car: 91 Red Sled
When you start to detonate you'll notice a HUGE power loss and the knock counts will go up for about 3 to 4 seconds from say 12 counts to 18, to 25, to 34, etc, for at least 3 or more "data screens". You don't have knock so keep going until you do get knock OR major power loss. When you reach your max, get some way to measure performance (track or g-tech or tazzo) and take out a degree of timing until no power loss is noticed. You don't want to run the MOST timing. Just enough to make no difference in performance is the best place.
86CamaroDan
Sep 29, 2015 10:08 PM
GTAman
Sep 21, 2015 09:57 AM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
CORV3TT3
Aug 23, 2015 11:26 AM
