who has swaped from a lo3 to a lo5
Old Sep 20, 2002 | 01:05 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
and what did you have to do to it to make it run right while keeping it tbi.
Old Sep 20, 2002 | 07:57 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
For a VERY smooth transition you would need 350 injectors, knock sensor and 350 chip.
You can get away with just the knock sensor and increase the fuel pressure on the 305 injectors (which will be tricky to get perfect) and run the 305 fuel curve.
Old Sep 20, 2002 | 12:31 PM
Car: 89 Camaro RS
Engine: 355 TBI
What will happen if i dont put the 350 knock sensor in, And where can i get a 350 chip? I already have a tb off of a cop car that's has the 65 lb hr injectores in it
Old Sep 20, 2002 | 01:12 PM
The 305 knock sensor will detect knock in a 350 engine when there is none due to the larger displacement of the 350. Knock sensor is a $35 piece. So the 305 sensor "will" work but you engine may become retarded
Brian
Old Sep 20, 2002 | 11:22 PM
Car: 89 Camaro RS
Engine: 355 TBI
What do you mean by my engine may become retarded? And what is the part number for the knock sensor that I need
P.S. Thank you for all of your help
Old Sep 24, 2002 | 05:55 PM
Boham92RS's Avatar
I swapped my LO3 for an LO5 and everything went very smoothly. Part numbers I used:
350 Truck Injectors(2) GM Part#17112493
350 Truck Knock Sensor GM Part#10456288
350 Truck Knock Module GM Part#16128261
I used an ANLU chip for a 350 Caprice.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
john204481
Sep 7, 2015 03:22 PM
