I am in a bit of a dilemma right now. I can get a free TPI set up to replace my TBI system. Do you think I should go through with putting it on, i know free power is always good, but is it worth the amount of work that I'll be putting out to get it installed, I'll only be able to work on it for about an hour anda half a day, but i dont really have a limited amount of days. What do you guys think?
The hardest part of the conversion is changing the fuel pump, you can always get an inline pump to boost pressure and set the return via a fpr to keep pressure up.
Then there's the wiring issue, but hopefully you got the whole thing so you just swap over the whole ecm unit and connect the proper sensors to it.
I was aware of the fuel pump issues and possible wiring problems, but im not sure if the guy that has the TPI system has the ecm, that may be a bit of a problem. I'll try to find what i can in the next few days.
