LO5 ZZ4 Cam
Subscribe
Sep 21, 2002 | 09:25 AM
I am rebuilding an LO5 with stock heads. I want to put in the ZZ4 cam. My question is can I do it with stock valve springs, Stock Lifters, Stock rocker arms, and stock push rods?
I will be replacing the heads later with AFR, but wanted to go ahead and get the cam in so I don't have to take EVERYTHING off next fall when I put on the AFR's.
Reply 0
Sep 21, 2002 | 09:57 AM
I believe that you can. Someone correct me if I am wrong.
Reply 0
Sep 21, 2002 | 11:27 AM
I think the L05 is flat tappet where the ZZ4 is a roller cam. If you get roller lifters you should be good to go though.
Reply 0
Sep 21, 2002 | 03:42 PM
Lo5 is roller lifter.
Reply 0
Sep 21, 2002 | 05:47 PM
PaulD ("guy" as he is known to my 3 year old) is correct so long as the LO5 is from a car. GM car v8s got roller lifters from 1988 if memory serves. But the truck LO5 versions didn't. If it's a truck LO5, then it will be flat tappet. Truck sbc didn't get them until the L31 for the 1996 model year. HTH. - Ken
Reply 0
Sep 21, 2002 | 05:58 PM
Thanks for clearing that up Ken.
Reply 0
Sep 22, 2002 | 04:33 PM
Thanks Chief, I wasn't sure if the truck motor was called an L05 or not.
Hope you had a good weekend. I started the Trans-go installation last night. As usual, nothing is easy. I'm going to have to remove the passenger side cat for access to the servo. Oh joy.
Reply 0
Sep 22, 2002 | 09:57 PM
yeah yeah yeah get a ZZ4 cam.
see sig
Reply 0
Sep 26, 2002 | 09:10 AM
Quote:
Truck L05 is VIN K, car L05 is VIN 7, FYI.
Reply 0
Sep 26, 2002 | 10:23 AM
zz4 cam with stock springs??!? you sure? The zz4 cam has a .510 exhaust lift. The stock springs can handle that?
Reply 0
Sep 26, 2002 | 07:29 PM
what is the rpm range on the zz4 cam and is it roller
Reply 0
Sep 28, 2002 | 04:13 PM
Quote:
nope, you need to get some GM ZZ4 springs or LT4 hotcam springs
Reply 0
Sep 28, 2002 | 04:14 PM
Quote:
yeah its a roller cam.
Reply 0
Sep 28, 2002 | 06:40 PM
1500-5500 rpm
Reply 0
Subscribe
