stalling problems
Old Oct 3, 2002 | 09:13 PM
ds83z28's Avatar
stalling problems
hi i have a 83 z28 cfi and lately ive been having stalling and low idle problems i have new plug wires fairly new plugs new coolant temp overheat sensor new temp sensor and new fuel filter.sometimes when i start my car it will stumble and die right away unless i give it gas kind of like its got a carb finally after giving it gas the idle will even out to about 500 .other times it will fire right up and idle beetween 800-1000rpm . but anyways when i start my car and pull out pf a parking spot and hit the brakes or turn a corner the idle will drop and it will stall .the computer isnt throwing any codes and a friend of mine who has a tbi truck says it happens all the time to him and is just an ailement of old chevys that if you dont keep on the gas sometimes it will just cut out.so is this just an old chevy ailment or is my computer going because im out of ideas and its a big pain in the *** seeing as how this happens almost every day. any help is greatly appreciated thanks.
Old Oct 10, 2002 | 05:30 PM
ds83z28's Avatar
thanks for all the help i really appreciate it
Old Oct 11, 2002 | 07:13 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
How does the injector spray pattern look? Nice even cone shape or more of a dribble.
Sounds like it could have some injectors clogging.
Old Oct 11, 2002 | 09:13 AM
flotsamm's Avatar
Bad ignition control module? IAC? TPS? Fuel pump? Coil? Timing off? Maybe run a pressure check on the fuel system. If that turns out okay perhaps start looking at ignition related items.
Old Oct 11, 2002 | 09:31 AM
Forgot that a carbon clogged IAC valve can cause the same problem. That was what was wrong with my wifes Fiero.
Old Oct 12, 2002 | 11:47 PM
ds83z28's Avatar
i hooked up a scan tool and there were no trouble codes and the tps is at normal voltage but im thinking iac valve but can anyone tell where it is located on the intake manifold ?and how do test/clean it ? thanks for the help
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
