TBI - Injector question
Old Oct 4, 2002 | 02:33 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
When i just have the car idling and i pop the hood i can hear a buzzzzing noise from the tbi is that good or bad i just never thought they were so loud
thanx
Old Oct 4, 2002 | 03:11 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
your open element is what makes it so loud. The TBI injectors are quite noisey. Paper just doesnt cut the noise down like the stock steel air filter housing.
Old Oct 24, 2002 | 11:56 AM
scifoo's Avatar
To Check the TBI Fuel injectors, you can use a volt meter and remove the leads ,set the meter to OHMs and touch one lead with one test wire and the other lead with the other test wire on one injector at a time and if the readings are between 1.0 and 2.0 your ok if they are out of that range they are fried...also if they are clicking really really bad........ Replace em
Old Oct 24, 2002 | 12:02 PM
Slade1's Avatar
If you think they're loud now, put in an underpulley kit.. that quiets down the engine bay area so much that the injectors almost fooled me into thinking my rocker arms were clacking...
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
