? regarding fp on 454 tbi
Old Oct 23, 2002 | 11:21 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Ok I have a 454 tbi i'm swapping on to my monte and i'm working on the fuel system. First off i'm wanting to use an external fuel pump because my car originally had a mechanical pump. I found that a pump from an 85 ford truck with mpi uses a nice external pump and comes with all the mounting brackets. It is rated for a max of 95 psi but as I understand it this shouldn't be a prob because the tbi reroutes the extra fuel back to the tank so the pressure will stay in the 15-20 range. Here is my question will this pump have enough volume to support 300-350 HP. Second I was looking through a hayes manual for an 89 chevy truck, yes I know their junk i bought it for the wiring diagram, and i found something that doesn't seem right. It says that the 454 tbi uses a special high output pump and it runs at 26-32 psi. Is this right? Does it mean the injectors will take a higher psi than other gm injectors? Thanks for your input any info will be greatly appreciated. :hail:
Old Oct 24, 2002 | 07:18 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Since Mustangs change their pumps to the similar 255 ltr/hr that we do for over 300hp, I doubt the stock truck pump will do it either.
As far as I know, all the tbi systems run 9-13 psi stock but they all can run 26psi if needed but you would need a vacuum regulator or major chip tuning to prevent flooding the engine at idle. You didn't say if you were swapping the 454 TBI onto a small block or big block engine. With a small block you are going to still need a lot of chip tuning with 454 injectors and a 300hp + engine.
Old Oct 24, 2002 | 02:51 PM
Chop_Top's Avatar
I use the Ford pump with a Holley 670 in my beast. It has the 330HP gm crate goes 10,000 puonds and uses more gas than any two Third Gens.
Works great...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
