Pickup Coil Replacement
Old Oct 23, 2002 | 09:41 PM
BlownBurb's Avatar
It appears the pickup coil or module in the distibutor of my 91 truck is bad. All of the threads I have read indicate that the distributor was removed to replace the pickup and module. My service manual does not give enough detail. Can someone tell me absolutely whether or not the distributor has to be removed and why?
Old Oct 24, 2002 | 06:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Pickup Coil Replacement
Distributor needs to be removed from engine. Drive roll pin out of gear at bottom of distributor, pull shaft out, remove snap clip, now can get pickup coil off. Dimple on gear goes in-line with rotor tip when reassembled.
May need to use carb cleaner (GumOut) on shaft and work it in order to pull it out of housing. Varnish builds up.
RBob.
Old Oct 24, 2002 | 08:14 AM
TBI305Camaro's Avatar
Thats pretty much it. Its not to difficult. Try to mark the distributer and get it back in the right way or your timing is gonna be way off. Mid as well just buy a timing light if you dont have one already.
Old Oct 24, 2002 | 10:33 PM
BlownBurb's Avatar
Thanks.
When looking under the cap, the pickup coil seemed so close but was yet so far.
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
TheExaminer
Aug 25, 2015 07:34 PM
Winchester1094
Aug 18, 2015 10:23 AM
