How much HP from this setup?
Old Oct 15, 2002 | 09:18 AM
TBI305Camaro's Avatar
Ok my lo3 is coming out of the car in the next few days. Im going to get a 9C1 LO5 (l98 cam/lt1 bottom end 9.6:1 comp) I know this isnt a powerful motor but i need a motor asap and this is the best deal i have found. Ill be running a edelbrock TBI intake, ultimated TBI mods, cop car chip, bigger injectors, 3'' hooker supercomp headers and 3'' hooker catback...let me know your feedback...im hoping to make this a hassle free swap.
Old Oct 15, 2002 | 11:13 AM
vjo90RS8's Avatar
Car: 2002 Z28
probably around 250HP 350 ft-lbs
Old Oct 24, 2002 | 11:42 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
sounds about right.
Old Oct 25, 2002 | 07:13 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
250hp does sound about right and you might want to throw in the S10 4.3L 95+ torque converter in there while the engine is out and grab a little more takeoff power. That combo should put you in at least the mid 14's which is a drastic difference from a stock L03.
Old Oct 25, 2002 | 10:30 AM
well we have an update. I did get the motor listed above. Instead of the TBI setup im going with a holley street dominator intake (idle to 7200rpm), 670cfm holley street avenger carb, hedman long tube headers running true duals to 2 chamber flowmasters...think i grabbed any extra power with this setup.
250hp will be much much better than the lo3...plus im sure the lo3 lost a few ponies due to its milage. the l98 cam will probably pull alittle better to. this summer im gonna get heads and a cam so ill be looking at 350hp at least.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
