Do holley 85lb injectors fit into a gm injector pod?
Old Oct 7, 2002 | 06:37 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I don't think they will, but spdc2000.com has them for $57 each, which is cheaper than gm injectors.
Old Oct 7, 2002 | 08:07 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Not sure about that one. Did you check with Holley? Don't be surprised if they are clueless but it's worth a try.
Old Oct 7, 2002 | 10:37 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Old style holley injectors don't really have a good reputation to begin with. I use the Holley 670 with the late model injectors (Delphi) that came with it. I'm not sure about the older style holley injectors, but the ones I have are smaller in diameter than the ones on the stock TBI. I was going to try to swap the origional injectors back in so I would stop running so rich due to the 57pph injectors on the Holley unit. But of course, the stock ones were to wide in diameter
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Keith5
Aug 27, 2015 04:37 PM
tmellott89
Aug 16, 2015 02:58 PM
89lsc
Aug 14, 2015 04:58 PM
