TBI Guys/Gods help!
Old Oct 9, 2002 | 08:12 AM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
TBI Guys/Gods help!
I posted to the Tech/General Engine thread about my engine problems. Click over to read through and give me a hand with this, please.
Tech/General Engine Post
Old Oct 9, 2002 | 08:58 AM
Snowdog 91 Formula's Avatar
Oil Leak?
You may have an oil leak on the passenger side. Maybe your valve cover is leaking.... have you looked under the car to see?
You may need to clean up your engine to pinpoint where it is.
That's my guess.
Old Oct 11, 2002 | 01:07 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Is your car overheating? If the head gasket is damaged it can push cylinder pressure into the coolant causing it to overheat. If the "smoke" smells sweet and makes you sick to your stomach then you've got a blown head gasket my friend. If you find out it is tranny fluid leaking onto the exhaust DON'T DRIVE YOUR CAR! ATF has a much lower flash point than oil and you could have a fire very quickly.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
