82 trans am w/cfi 305
Old Oct 31, 2002 | 07:32 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
hi i am a new member and I recently purchased an 82 trans am with the crossfire fuel injection. The car has 192 000km and it is time for its tune up. I am running on a low budget so can anyone please tell me what I should get for a performance tune up. Like I will change the oil and put a new filter in but for the air cleaner i was thinking k & n but that would set me back $130 cnd because the cfi has 2 filters. Umm..i heard around that older cars like this one may need new oxygen sensors and when replaced give the car much more power than pervious. Is this all valid..Can someone please reply and give me pointers and low budget tune up things...Maybe something like larger headers off of an older chevy truck with a 305..or are the headers mostly the same...please reply ASAP.
Old Nov 3, 2002 | 08:14 PM
Berlinetta's Avatar
Yeah, it would probably be a good idea to change the oxygen sensor. That little bastard can screw gas mileage and performance up more than just about any other sensor. The plugs are a given for a tune up but a new distributor cap, rotor, and plug wires might also be a good idea. Go ahead and check the timing and adjust it if neccesary. I've heard advancing it a couple of degrees can get a little bit of extra performance. If you use decent quality parts doing all this, you should see a small improvement in performance. K&N filters are a good idea but as you said, they ain't cheap. Are you sure they cost that much? Damn that seems pricey.
Old Nov 5, 2002 | 07:11 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Cool, Winnipeg. What color is your '82 T/A? Maybe I will see you around sometime.
Old Nov 6, 2002 | 08:41 AM
Car: 82 T/A
ok
ok thanks for the tips..im going to install the 02 sensor, new spark plugs, new wires, new filter,new oil filter, new tranny fluid, posi track fluid, and engine oil..Maybe new headers..but those are a fortune..
Bye the way..one person wanted to know..its a black 82 trans am.
And i live in stvital:lala:
Old Aug 7, 2005 | 11:30 AM
82knightrider's Avatar
Transmission: TH200C....700R4
How did the oxygen sensor and everything else work out
Is your CFI still running
Old Aug 8, 2005 | 03:38 PM
Car: 82 T/A
ha
i took out the cfi long time ago in place of a 69 camaro engine that was built up by myself.
I still have the ported cfi intake and would like to see how everything would work now that there are actual sized ports.
But thats a little later on.
Orr89RocZ
Apr 25, 2016 08:28 AM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
Leggman1
Aug 6, 2015 04:15 AM
