smoke
Old Nov 6, 2002 | 10:15 AM
89IrOc350's Avatar
smoke
ok i over heatedmy 91rs 305tbi trying to get back from work 1 day andi replaced the thermstat plugs and fushed the coolant
whenever i start the car it smokes out the exhaust pipes i i hi the gas it just pours out whats the problem here what can i do to fix it
Old Nov 6, 2002 | 11:09 AM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
I'm no expert but it sound like you blew the gasket or cracked a head. Watch your spark plugs and figure out which side it is. Then you'll have to remove the head, replace the gasket. If you cannnot see a crack, get it to an engine shop to have it magnafluxed.
Old Nov 6, 2002 | 11:48 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
or id check for a warped or cracked head, maybe even a cracked block. Something is letting alot of coolant into the combustion chambers.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
