cam size
Old Nov 11, 2002 | 08:02 AM
Mike1's Avatar
cam size
I am looking at a Lunnati cam, grind is 215/218 dur, 489/503 lift and lobe sep is 115. What do you guys think about this cam with a 350 with 670 tbi, bored tbi intake and maybey edlebrocks new "new & improved" performer heads? I can get this cam for $75.00 from a guy I know may even be able to get custom burned chip that was burned for it by Howell Eng. for another $25.00 if he still has it, but its for a truck computer. Need some opions on this combo.
Old Nov 12, 2002 | 08:17 AM
Mike1's Avatar
come on guys, what do you think?
Old Nov 12, 2002 | 09:42 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Sounds like a good tbi cam to me.
I'm using the Crane Powermax (Compucam) 2030 HR.
115-116 lobe separation makes really good vacuum signal for tbi setup to function properly.
-Rich-
Old Nov 13, 2002 | 01:11 AM
BahamutRS's Avatar
Sounds good to me as well. I almost went with a '96 Z28 LT1 camshaft, but I sold the RS before I could put it in.
Old Nov 13, 2002 | 01:36 AM
iroc22's Avatar
I'd say the LSA is just about right for that amount of duration. As long as the LSA is keep up there with the duration, you should be fine.
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I like the sounds of that cam, alot. Thats with 1.5 rockers? Seems just about perfect to use with good aftermarket heads.
Old Nov 13, 2002 | 08:20 AM
Mike1's Avatar
Is there a way to verify specs on cam, if I get it? Also what kind of power would I be making as described above?
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
