New Jet regulator
Old Nov 22, 2002 | 04:01 PM
headhawg7's Avatar
New Jet regulator
I have a 383 Stroker in my 92 Camaro. It had a 305. I am using the stock ECM, TBI and basically everything else. I just put in a new AFPR from Jet products. It runs good and idles good. When I am cruising and floor it, it takes aff really quick BUT as it is accelerating it feels like it is pulling and jerking the faster it goes. I mean it still accelerates really fast but just kinda jerks. It does jerk my entire body you can just kinda feel it. Its hard to describe this crap in words. But anyways will adjusting the pressure up or down fix this? The pressure reads about 16psi. With the 383 and bigger cam should this be higher. Any help would be appreciated. Thanks Danny
Old Nov 22, 2002 | 04:58 PM
NJ SPEEDER's Avatar
you need more fuel and timing. did you get a custom chip for it? was the chip made from data logging? did you swithc to bigger injectors?
later
tim
Old Nov 22, 2002 | 05:29 PM
JPrevost's Avatar
Car: 91 Red Sled
Need to know the size of the injectors, what kind of 383 you built etc.
Old Nov 23, 2002 | 06:41 PM
headhawg7's Avatar
I have the same injectors and I haven't had a chip made, yet. Do you think I need bigger injectors?
Old Nov 23, 2002 | 07:54 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
yes, you need larger injectors. My guess is, at very least, you need the 65pph 350 caprice injectors. Depending on the estimated power output of your 383, you may need larger. Regardess, you will greatly benefit from a custom chip. WinALDL is a great, great tool-i highly recommend using it. Drop the larger injectors in first though, so the chip can be tuned around them.
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
