TBI Parts question
Old Nov 24, 2002 | 10:57 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
TBI Parts question
84 pontiac trans-am 305 v8 5L have carb but looking to go TBI as i can toss in a turbo charger and such, just want to know what parts i woud need to replace / buy to get a working (a good working) TBI setup going and just how much it would be total im willing to put in the man hours
Old Nov 28, 2002 | 09:39 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Need the TBI unit: Should include injectors, fpr, and a couple sensors.
Need an intake.
May need a distrib that the ECU can talk to.
Need ECU (under dash, pass side) and Wiring Harness (can we say Painless?)
Need sensors: TPS and IAC (on TB), CTS (on intake), IAT (on air cleaner), MAP (on firewall), O2 (drivers side exh manifold, near #5 cyl spark plug), VSS (behind inst. cluster, we hope. if not, refer to VSS conversion (take the whole cluster, more wiring, and the vss off the donor's tranny speedo output)).
Make sure your fuel system is supplying 9-13 PSI. Use an electronic pump. You can go in-tank if you want, but.. eww.
Expect a 10-20 work hours, 15-25 if you're a perfectionist and clean everything you see. Anything less than 10 hours, you either shouldn't be asking simple questions or you missed something... or you're really lucky or I'm too tired to do time estimates
Old Nov 28, 2002 | 10:13 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
He can reuse the intake manifold on there, or get an aftermarket carb intake and use an adapter plate. The edelbrock and holley TBI manifolds are for '87-up cast iron heads, so finding one without having to machine it would be hard. Many people choose to go with a carb intake anyways. Just keep in mind you will need to disable egr in the computer chip if you're running an intake without it.
Old Nov 28, 2002 | 10:51 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
This is bringin back way to many memories... good, bad, and the oh **** spring when your drinkin on the job... I still hear that clank every now and then... and then I do this....
Old Nov 29, 2002 | 10:51 PM
Car: Camaro
Engine: 5.slow
Hey thanx for the help guys, what brand should i go with ill do a search but i want to find something fairly cheep that will give me the dependability and durability i need (and power ) need the power stuff too lol
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
1nastygta
Aug 8, 2015 07:38 PM
