Need Suggestions On What Intake To Get
Old Nov 28, 2002 | 01:15 PM
Ratstix's Avatar
i will be buying myself an intake for x-mas and am looking for your suggestions.
i need one with EGR. idle-5500 is my normal driving range.
i was thinking the wieland stealth but from what i understand that has no egr.
i will also be buying a lt1 cam soon if that matters.
Old Nov 28, 2002 | 05:37 PM
hydra512's Avatar
this is what i plan on getting when i put in my lt1 cam
Holley Pro-Jection aluminum Intake Manifold, jegs part number 510-300-66
Old Nov 28, 2002 | 05:42 PM
NJ SPEEDER's Avatar
that woudl also be the performance range of the edebrock performer tbi, or a regular performer intake.
you can save yourself a few bucks since you have the cowl hood and get an edelbrock performer intake or similar dual plain low rise intake, and put an adaptor plate on it.
later
tim
Old Nov 28, 2002 | 09:14 PM
Ratstix's Avatar
ok well maybe i'm just a total dumbass but i dont see a performer style intake with EGR. (on summit)
if i got a non EGR intake would i have to do anything else to the engine or PROM to compensate for it?
and also the only TBI adapter i could find was from holly, would that fit on an edelbrock intake?
Old Nov 28, 2002 | 09:27 PM
Ratstix's Avatar
ok guys. i think i found it. will thsi work with my engine.
anybody have any feedback on this aprticular intake?
http://store.summitracing.com/partde...t=14394&view=1
Old Nov 28, 2002 | 10:27 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
The intake should work. I think you need to drill the center bolt holes at a different angle to get the intake to work with your heads, as I think the intake is for pre-'87 heads. The holley adapter will work fine with an edelbrock intake. I'm not sure, but I think it needs to be at least 5/8" for your tbi to clear the egr on that manifold.
Also, keep in mind two things:
(1) The LT1 cam actually creates it's own egr in a sense, without needing an actual egr valve. I'm not sure how, but if you do a search, you could find out how and why it does.
(2) Keep a single plane in mind. The LT1 cam will help move your powerband up, which a single plane would complement, and it has been said that using tbi will actually make your powerband start up to 1,000rpm earlier than advertised, do to the fuel injection.
I am by no means an expert, though and have no personal experiance with manifolds. Do a search, and you will find A LOT.
Old Nov 28, 2002 | 10:31 PM
Ratstix's Avatar
well is there any intake that is a direct bolt on? i'd really like to not have to drill or do any "craftsmanship" of my own.
Old Nov 29, 2002 | 04:48 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
The best direct bolt-on intake for the tbi, is just the Edelbrock Performer TBI its supposed to just bolt right up with no worries.
Old Nov 30, 2002 | 02:29 AM
FLYNLOW92rs's Avatar
I thought the only intake manifold you could use with the TBI and STILL RETAIN EGR and require NO mods (ie direct bolt in) was the Edelbrock Performer TBI #3704
Am i wrong?.......
Old Nov 30, 2002 | 04:02 AM
radiateu2's Avatar
intake manifold
You are right Weiand name does not make a Stealth intake with EGR provision if you want a Weiand, look at the action plus 8024 It is the intake with EGR provisions for 1987-later cars and will operate in the powerband you want. I believe it too has the spread bore pattern too.
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
transamgta87
Sep 1, 2015 07:07 PM
InfinityShade
Aug 22, 2015 08:00 PM
