Need help w/ open element
Old Dec 5, 2002 | 03:57 PM
91AZBIRD's Avatar
Car: 91 Firebird
Engine: L03 305 TBI
Transmission: BW T-5
hey guys
i in the process of replacing my air filter and have been looking at different open element filter and was just wondering if 5 1/8" neck flange would fit on my LO3
thanks in advance
Old Dec 6, 2002 | 02:24 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
yes it will almost any standard one made for a 4bbl carb with a drop base will fit
Old Dec 6, 2002 | 10:03 PM
deadtrend1's Avatar
only problem with drop base is that you may need to bend the ignition coil back a little.
Old Dec 7, 2002 | 01:54 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I just did this. I got a non-drop based assembly like the tech article said and removed the collar that sits on top of the TBI. I tapped the air temp sensor to it and also pulled of fhe cowl cover. Sounds great. I used a peice of thick rubber to cover the whole distibutor and coil area, just incase it grounds or water seeps in it will be protected. I got my air cleaner from lopers for under $20.00.
Mike
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
