what do you guys feel about the vortec 305 heads
Old Dec 17, 2002 | 01:57 AM
92 z28's Avatar
what do you guys feel about the vortec 305 heads? im looking for a good set, and i know how important heads are, i just dont want to spend a fortune. what heads do you guys recommend? i plan on doing cam as well.
Old Dec 17, 2002 | 02:39 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The L30 Vortec heads? I dont have personal expirence with them, but I've read they arnt like the normal L31 (62 cc chambers) heads and they kinda suck. Go with the L31s and get them milled, throw them in with an LT1 cam and you'll be motoring
Old Dec 17, 2002 | 09:54 AM
1slow60's Avatar
I dont think that you really need to worry about the compression that much. Stock LO3s are 9.3:1 correct. Even with the bigger combustion chamber you should be around 9:1 which would work just fine beeing they are more efficient than the stockers. Just my 2 cents.
Old Dec 17, 2002 | 01:17 PM
iroc22's Avatar
I wouldn't worry about trying to get a set of 305 ones when the 350 ones milled will make more power than them because of worked-in power producing characteristics. The L31's (350 version) make more power and are easier to get ahold of. I don't see why you would go otherwise.
Old Dec 17, 2002 | 02:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i agree with mr canada
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
