Vortec Edelbrock Perf. RPM Install
Old Dec 17, 2002 | 05:22 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Hey all,
In two weeks I am going to be installing my vortec heads with my LT1 cam and Edelbrock Vortec Performer RPM intake.
My question is to all that have done this intake with a tbi adapter plate, hood clearance issues? The intake instructions said something about needing a new throttle bracket, will the stock bracket work?
Anyone who has done this or seen it done if you could provide some advice that would really helpfull.
The Vortec'th come'th alive!!:hail: :hail: :hail:
Old Dec 17, 2002 | 09:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
check out my site in my signature...i have a couple pages devoted to EXACTLY what you are talking about. there are pics, etc.
-brian
Old Dec 18, 2002 | 12:48 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Well you wont be able to have a wingnut on top of your air cleaner if you use a 14x3 element like I do, lol. It just rubs the bottom of the hood when you close it. I fabbed my bracket up different than Z28boy did (btw, he has a great sight), if I can snap a picture of that today I will.
Did it happen to list the part number for the bracket they recommend?
Old Dec 18, 2002 | 01:39 PM
Car: 89 Camaro RS
Engine: 305 TBI
No they didn't say. I guess I'll just try to tweek the stock bracket after I take a look at how it lines up. With the adapter plate on there can you use the drop base aircleaner with that silencer ring in there without it hitting the throttle cables?
Old Dec 18, 2002 | 05:21 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I just used Edelbrock's vortec bracket. Part number 8032. I think mine was about $25 from Jegs.
Old Dec 19, 2002 | 12:50 PM
JPrevost's Avatar
Car: 91 Red Sled
I made all my stuff fit:
RPM intake vortec heads
New motor mounts
1" adpator/spacer plate
Holley 670 cfm TB
14x3 drop base air cleaner.
All it took was cutting out some of the underbracing and banging enough clearance in the air cleaner base for the IAC and TPS wiring plugs. It never rubs. The modified base (hammer time) does require a dremel cutting tool on the air cleaner to make it fit flush but that took all of 2 minutes no more or you're taking too long.
Old Dec 19, 2002 | 02:13 PM
Car: 89 Camaro RS
Engine: 305 TBI
Well I just got my tbi adapter in the mail last night. Pretty nice piece. When I lined it up with my manifold the throttle circles of the plate don't line up perfect with the plenum of the manifold. I think I'm going to dremmel the edges of the manifold to match the circles at the top and then taper them back in.
Anybody else do that too?
Old Dec 20, 2002 | 10:11 AM
knoxbonnie's Avatar
New motor mounts
Holley 670 cfm TB
What underbracing are you talking about? Underbracing on the Air Cleaner base plate?
Just curious, I am thinking about upgrading mine to the Vortec heads as well with the ZZ3 cam. I have been eyeballing the kits from Scoggins Dickey.
Old Dec 22, 2002 | 07:42 PM
JPrevost's Avatar
Car: 91 Red Sled
The hood is made up of 2 pieces of metal above the air cleaner. The top is the shell and the bottom is the underbracing. More like the bones and skin. Cut out a hole for the air cleaner so the hood isn't as thick in that area and you shouldn't have a problem fitting an open element in.
Old Dec 22, 2002 | 08:33 PM
knoxbonnie's Avatar
Aaaaaahhhhhh....
Thanks, I appreciate that. I must have had a mental lapse going or something...
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
